On the post concerning fitting a larger rear tire.....
2.6K views 15 replies 7 participants last post by  George4
It was asked if installing a larger tire would effect the speedometer error and if the speedo drive is on the front or rear.
The speedometer gets a digital speed signal from a electronic component in drive line output.
So the answer is NO!,....no real connection to the wheels, but it may effect the speedo error to a relatively minor amount. Odometer and Speedometer accuracy varies with tire sizes, but also with tire wear.
I have experimented with this for over 40 years and have come to the conclusion that most speedometers will read faster than the indicated speed traveled. So unless your are replacing your rear wheel/tire with something utterly radical,.....don't worry.
#2 ·
...which has a direct relationship with one of the wheels... either the front or the rear. Don't they use one of the ABS rotors for speed pickup (I would guess the rear one)?
Going up a tire size in the rear will most likely make the speedo more accurate, that I agree on. But definitely there is a "direct" connection between the wheel and the speedo. A friend of mine used to water cut custom ABS rotors for BMW's to adjust for a 21" front wheel on GS's...
#3 ·
Thanks, MOMZ!
I guess my biggest concern is more with the odometer reading. An inaccurate speedo plus or minus 1-2 mph isn't a big deal to me. I just don't want the odometer to be adding mileage that isn't being driven.
#5 ·
Makes sense...
The overall diameter of the 180/65 tire is .2 inches (25.2" or 79.2" circumference) smaller than the stock 150/80 tire (25.4" or 79.9" circumference).
If there are any mathematicians out there (I was awful at math in high school): If I were to travel 500 miles on the stock tire, then trace that same route on the 180/65 tire, how many miles will the odometer say I've traveled?
#9 ·
In the grand scheme of things—Who cares if she’s kind of “off” by a little when she looks like this:
If your wife was hot AF, she’s not gonna be perfect.
Instagram: @rite_on_john
(Not an engineer)
#13 ·
A good number of owners have installed a 180/65 tire on their Bobbers. But so far no standard Scout owner has commented on installing the 180/65 tire. I'm thinking the Bobber's anatomy is similar/same to the regular Scout, so fitting "shouldn't" be a problem. But I would like the peace of mind I get with a Scout owner explaining he/she has installed the 180/65 without any issues.
#16 ·
It would still be the same concept
150 80/16 ------- 793 Revs/Mile *stock tire
180 65/16 ------- 800 Revs/Mile
180 70/16 ------- 778 Revs/Mile
Its pretty close. Just wondering why anyone would go with a 65 aspect ratio if a 70 ratio would be closer. But a 180 65/16 would definitely give more room with it being a little shorter as opposed to taller.
